August 3, 2021 at 1:00 pm
Ciel_yy
SubscriberI have generated a series of parameterized geometry models which only differ in one parameter(for example, the length in one of the part of the geometry model)
My purpose is to get a python script with the recording fuction by processing the first one geometry model manually. Then use the python script to automatically mesh other similar geometry models. However, something goes wrong when I use the script to process the second geometry model.
To figure out the reason for the question, I also get python script from the second geometry model with the same manual processing schedule. By comparing the two python script, I find the Ids of the same part of the two different geometry model has changed, which leads to the error above.
Just as shown in the picture Below, I mesh the same part of the geometry model as well as start to record python script. I click the Mesh button then select Method button then select the particular part of the model which is shown in violet in the picture Below . The corresponding python scripts for the the first and second geometry are show below.
August 9, 2021 at 3:44 pmAniket
Ansys EmployeeThe 25 (not 23) that you see is the id of the object in the tree, whereas 68 or 69 is the reference_ID that you see in the Selection information window.
Both things can change depending on the source of the geometry. You will need to use some other logic such as bounding box, part name, volume, number of faces etc to filter out the bodies.
-Aniket
August 17, 2021 at 9:27 amCiel_yy
Subscriberthanks very much for your answer. I am very lucky to get the reply from you who I would like to invite to answer the question(but I am new to here, know nothing about how to invite others).
I intened to use the part name to filter out the bodies, but nothing useful info has been found.
I have tried a lot of script, but no one works.
May u offer me some example using the part name to filter out the bodies.
Thanks very muchMarch 30, 2022 at 7:15 amsch401
SubscriberDo you know how to find the reference ID?
March 30, 2022 at 11:36 amAniket
Ansys Employeereference_ID can be found in selection information.
-Aniket
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
7742
4502
2961
1449
1322
