Platform
Platform
ANSYS multifield parallel model
    • memo
      I am trying to perform a Multiphysics simulation (fluid flow (CFX) and Transient structural) on my university's HPC. I can work with the GUI on windows. Currently, I am just able to run the simulation in parallel mode using only one node and N partitions (using the -np command). However, I have access to three nodes and would like to use all of these nodes to run the ANSYS APDL in parallel mode.
      Can anyone tell me how can I use three nodes each with N partitions, please?
      My fluid and structure parts only contain 300K and 200K elements, respectively. Currently, I am using 90 partitions for the fluid and 30 partitions for the structural side. Why my Multiphysics simulation is so slow?
      Thanks in advance.
    • Stephen Orlando
      CFX performance decreases when the number of elements per partition is this low. The percent overlap between partitions in the .out file should be 20% at most. Decreasing the number of cores should improve performance.n
