March 14, 2023 at 9:30 am
Yinzhong Hu
SubscriberHi~
Can ansys provide strain data directly displayed in strain nephogram?
March 14, 2023 at 10:38 am
SubscriberPlease insert an example image of a strain nephogram in your reply so we know what you mean by that term.
March 14, 2023 at 2:15 pm
March 14, 2023 at 3:14 pm
SubscriberGoogle Translate: Now I get response data for 15 locations. Actually, I have the strain values of the actual objects at these locations. I was wondering if I could get his strain contour by directly entering the strain values at those 15 locations. In short there is no such process here that can be simulated using ansys
Answer: Go into SpaceClaim and split the face using an XZ plane to make that line, then create 13 planes parallel to the XY plane and split the face to make interior vertices. Now you can report 15 strain values at those 15 vertices.
答案:进入 SpaceClaim 并使用 XZ 平面分割面以制作该线,然后创建 13 个平行于 XY 平面的平面并分割面以制作内部顶点。 现在您可以报告这 15 个顶点的 15 个应变值。
March 15, 2023 at 4:21 am
Yinzhong Hu
Subscriberthank you!!
3930
2649
1861
1272
610
