May 24, 2023 at 2:03 am
Theja Sai
Subscriber -
May 26, 2023 at 12:11 pm
Oleg
SubscriberDear Theja Sai,
The warning regarding the changed reference values is not of a trouble itself (click on "Re-read reference values"). My concerns are about the red error messages you see in the background. Looks like the Motor-CAD executable could not be located (please, hover over the “Traceback most recent call” message to see the contents). Could you please check the path in the Motor-CAD GUI under “Defaults > Automation > ActiveX” and adjust it if needed; then re-execute the export procedure. Let us know about your findings.
Kindest regards — Oleg
May 26, 2023 at 5:23 pm
Theja Sai
SubscriberHere is the error codes:
2023-May-26 10:19:45.915248 ERROR Input integration functionality missing although expected.2023-May-26 10:19:45.873571 ERROR Running script source failed.2023-May-26 10:19:45.873571 ERROR Traceback (most recent call last):File "c:/Ansys_Motor-CAD/2023_1_1/Motor-CAD Data/optiSLang/Integration/MotorCAD_ci.py", line 33, inimport MotorCAD.MotorCAD_integration as integImportError: No module named MotorCAD.MotorCAD_integration2023-May-26 10:19:45.450491 ERROR Input integration functionality missing although expected.2023-May-26 10:19:45.411492 ERROR Running script source failed.2023-May-26 10:19:45.411492 ERROR Traceback (most recent call last):File "c:/Ansys_Motor-CAD/2023_1_1/Motor-CAD Data/optiSLang/Integration/MotorCAD_ci.py", line 33, inimport MotorCAD.MotorCAD_integration as integImportError: No module named MotorCAD.MotorCAD_integration2023-May-26 10:19:45.109321 ERROR Input integration functionality missing although expected.2023-May-26 10:19:45.067529 ERROR Running script source failed.2023-May-26 10:19:45.067529 ERROR Traceback (most recent call last):File "c:/Ansys_Motor-CAD/2023_1_1/Motor-CAD Data/optiSLang/Integration/MotorCAD_ci.py", line 33, inimport MotorCAD.MotorCAD_integration as integImportError: No module named MotorCAD.MotorCAD_integration -
May 31, 2023 at 7:59 pm
Theja Sai
SubscriberCould anyone respond on this?
June 1, 2023 at 6:07 am
Oleg
The file manager reports that it can't find the needed integration script. That is an uncommon error. Could you, please, check the contents of the folder: {Motor-CAD install dir}\Motor-CAD Data\optiSLang\Integration\MotorCAD and see whether the file "MotorCAD_integration.py" is there (this one looks to be missing). If it is not there, please, reinstall Motor-CAD on your machine.
Kindest regards
- Errors about integrate executable into ANSYS Workbench using ACT
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- Optislang workbench add-in
- Parameter relationships for Optimization
- Design of Experiment points: Design Exploration
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Parametric study: Batch mode
5250
3299
2469
