October 29, 2021 at 8:43 pm
jamie.fuery.2018
SubscriberHi everyone, I'm trying to add Optislang optimization to my project schematic in the parameter set 'box'. After I double click (or drag) the optimization into the project schematic, workbench says 'busy' inn the bottom left and after about 20 seconds it does not add to the schematic and acts as if nothing has happened. Anyone got any clues/fixes for this? Thanks in advance. -
August 24, 2022 at 9:31 am
Markus
Ansys EmployeeHi Jamie123,
the Problem you describe here might be related to a Licensing update with 21R2.
So, you can update your Licenses or use an optiSLang Version 21R2.1 or later?
Best regards,
Markus
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- Optislang workbench add-in
- Errors about integrate executable into ANSYS Workbench using ACT
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Parameter relationships for Optimization
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3850
2627
1853
1246
600
