Ansys output ( Deflection ) is varying with change in method of bonded contact/connection. Pls help!
TAGGED: bonded-contact, buckling-analysis, static-structural
February 2, 2021 at 8:49 am
Sundarram
SubscriberI have a tank made of Polypropylene, I wanted to perform hydrostatic pressure study for deflection. I got the results. I wanted to validate it. I have few queries in the results. My tank is supported with C channels on the outside, and circular beams on inside. I took tank from Unigraphics NX. Made beams as line body in Ansys design modeller,
When i performed the analysis first with bonded contact with all program controlled settings. I got solver pivot error for circular beams. When i suppressed the Circular beams and tried for tank with C channel, I got the deflection value. ( no error).
February 2, 2021 at 12:44 pmAshish Khemka
Ansys EmployeeFebruary 2, 2021 at 1:29 pmSundarram
SubscriberThank You ashish sir . But can you explain me the significance of radius value in Beam formulation? . Why is there a smaller deflection if we increase the radius value?.Regards,nSundar RnViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5162
3251
2443
