March 13, 2021 at 6:43 am
xuduan
SubscriberI have connected an excel file to parameters in DesignModeler. I can confirm that this updates the 3d geometry when I open the excel file and modify it in Workbench. nHowever, when I open the excel file without opening it in Workbench, it does not recognize that the values have changed. nCan anyone suggest a solution to this?. -
March 15, 2021 at 4:14 am
Keyur Kanade
Ansys EmployeePlease check if you are saving file correctly. Check if you have write permissions. nYou can find few videos on this function on youtube. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
