Ansys Products
Ansys Products
ANSYS PExprt – “ERROR: ‘pexprt’ licence checkout failure”
    • Kishore_Seshadri
      I am facing the following issue when launching PExprt from start menu.
    • George Karnos
      Can you please post a screenshot as we are not permitted to open files.
      Thank You!
    • Kishore_Seshadri
      Sure. This is the error stated
    • George Karnos
      Do you have a firewall active?
      If so, as a test, can you shut it down and try to run?
    • Kishore_Seshadri
      I do have a firewall active. I tried a restart, it did not work. I have also tried to disable the firewall & antivirus set-up. It hasnt improved.
    • Kishore_Seshadri
      PExprt and PEmag are not available in the Ansys Electronics desktop under the projects menu as well, although it is installed.
Viewing 5 reply threads
