ansys piezoelectric simulation help
    • Caterina Azais
      Hi everyone!
      I am new to ansys and have been really struggling to get my code working.... I want to simulate the voltge output of a dielectic material under a uniform pressure acting on the top lectrode. Can someone please please please help me? Thanks !
      ! Geometry
      l = 5e-3 ! beam length, m
      w = 5e-3 ! electrode width, m
      t = 100e-6 ! thickness, m
      !Loading
      PRES= 10000 !pressure loading, Pa
      ! Material properties
      Y = 140e9 ! Young modulus, Pa
      mu=0.358 ! Poisson ratio (nearly incompressible rubber)
      eps=8.17 ! electrical permittivity, relative
      eps0=8.854e-12 ! free-space permittivity, F/m
      /VUP,1,z
      /VIEW,1,1,1,1
      /PREP7
      ET, 1, 5, 3
      ! == Material parameters
      ! -- Elastic coefficients, MPa
      c11 = 209.71e9
      c12 = 121.14e9
      c13 = 105.36e9
      c33 = 210.9e9
      c44 = 42.5e9
      c66 = 44.28e9
      tb,ANEL,1
      tbdata, 1, c11, c12, c13
      tbdata, 7, c11, c13
      tbdata, 12, c33
      tbdata, 16, c66
      tbdata, 19, c44
      tbdata, 21, c44
      ! -- Piezoelectric coefficients, pC/um2
      e13 = -0.61
      e33 = 1.14
      e15 = -0.59
      tb,PIEZ,1
      tbdata, 3, e13
      tbdata, 6, e13
      tbdata, 9, e33
      tbdata,14, e15
      tbdata,16, e15
      ! -- Dielectric constants
      emunit,EPZRO,8.854e-6 ! pF/um
      mp,PERx,1, 7.57
      mp,PERy,1, 7.57
      mp,PERz,1, 8.31
      ! -- model and mesh block
      block,-l/2,l/2,-w/2,w/2,0,t
      ! Set the merging tolerance (adjust as needed)
      KETOL = 1.0e-5
      vmesh,1
      ! Structural BC - fix the displacement of bottom face
      nsel,s,loc,x,-l/2
      d,all,ux,0
      nsel,r,loc,y,-w/2
      d,all,uy,0
      nsel,r,loc,z,0
      d,all,uz,0
      nsel,all
      ! Electrical BC
      nsel,s,loc,z,0
      nsel,r,loc,x,-l/2,l/2
      nsel,r,loc,y,-w/2,w/2
      cp,1,volt,all
      ng=ndnext(0) ! ground node
      nsel,all
      nsel,s,loc,z,t
      cp,2,volt,all
      nl=ndnext(0) ! load node
      nsel,all
      /SOLU
      antype,static
      cnvtol,f,1,1.e-6
      cnvtol,amps,1,1.e-6
      cnvtol,volts,1,1.e-6
      d,ng,volt,0 !put ground node to zero volts
      nsel,s,loc,z,t
      sf,all,PRES,0  !apply pressure
      nsel, all
      solve
      fini
      /POST1
      nsel,all
      pldisp,1 ! display deformed/undeformed shape
      andscl ! animate deformed/undeformed shape
      nsel,s,loc,x,l/2
      nd=ndnext(0) ! pick node for display
      nsel,r,node,,nd
      prnsol,epel ! print strain
      prnsol,volt ! print voltage
      nsel,all
      fini
    • Erik Kostson
      Hi
      The restrains, do not seem to be very well defined perhaps – but one issue is the pressure load (sf) sf,all,PRES,0 applies a 0 pressure which is not what one uses as a load (zero loads), and it applies it to the sides as well as the top –
      so go through the command reference (e.g., sf command) and some simple apdl examples and then try to understand what you want to do and then how to do it using apdl – I would suggest to do this in workbench, where it is much easier.
      SF (ansys.com)
      Finally go through one of our courses:
      https://www.youtube.com/playlist?list=PLtt6-ZgUFmMKFfbOBhmCwG30KIVyvhDop
      If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
      Hope that helps
    • Caterina Azais
      thank you so much, that seems to be making much more sense now... I have changed the code as follows, however when i print the PRNSOL commands it says that the S, D, .. data are not available and hence its ignored. What is the problem? Thank you !
      ! Geometry
      /VUP,1,z
      /VIEW,1,1,1,1
      /PREP7
      ET, 1, 5, 3
      c11 = 209.71e9
      c12 = 121.14e9
      c13 = 105.36e9
      c33 = 210.9e9
      c44 = 42.5e9
      c66 = 44.28e9
      tb,ANEL,1
      tbdata, 7, c11, c13
      tbdata, 12, c33
      tbdata, 16, c66
      tbdata, 19, c44
      tbdata, 21, c44
      e13 = -0.61
      e33 = 1.14
      e15 = -0.59
      tb,PIEZ,1
      tbdata, 3, e13
      tbdata, 6, e13
      tbdata, 9, e33
      tbdata,14, e15
      tbdata,16, e15
      mp,PERx,1, 7.57
      mp,PERy,1, 7.57
      mp,PERz,1, 8.31
      KETOL = 1.0e-5
      vmesh,1
      ! Structural BC
      nsel,s,loc,z,0
      d, all, volt, 0
      d,all,ux,0
      d,all,uy,0
      d,all,uz,0
      nsel,all
      nsel,s,loc,z,t
      SF,ALL,PRES,10000 ! APPLY PRESSURE LOAD
      NSEL,ALL
      FINISH
      /SOLVE
      OUTPR,,LAST
      /OUT,SCRATCH
      SOLVE
      FINISH
      /POST1
      /OUT,
      PRNSOL,S,COMP
      PRNSOL,EPEL,COMP
      PRNSOL,EF,COMP
      PRNSOL,D,COMP
    • Erik Kostson
      happy we could help.
      See the video (post process) :
      Also see the SET,LAST,LAST  POST1 command in the command reference
      Erik
Viewing 3 reply threads
