ANSYS Pump Tutorial
    • KMAC
      I started working through the turbosystems quick pump tutorial via the help menu, it states to edit the blade set to:
      "trailing edge definition > line of rotation on hub and shroud" (as below)
      However the option for this doesn't appear on my screen, just cut-off or square which is already selected.
      I have ANSYS student version 18.2
      Thanks in advance for any help.
Viewing 0 reply threads
