Materials
Materials
Ansys R19 Structral analsys material information is not full
    • Kasım Alperen Ateş
      I can not seen materials characteristic. I need tensile yield strenght. Because when I run the system for safety factor or strain , I seen warning and error. The program can not found tensile yield strenght. Could you help me for this trouble ?
    • David Mercier
      Hi,can you edit the value and enter manually inputs? Then you can get data from ref papers or technical datasheets.
      If you can look into the Material Data for Simulation: https://www.ansys.com/en-gb/products/materials/materials-data-for-simulation
      Or if you have access to Ansys Granta Products (EduPack for teaching or MI / Selector for research/industry). Here a screenshot from Selector.
      Cheers
