Ansys Products
Ansys Products
Ansys remote solver manager user
    • lennartm
      I have strange problem. It seems that the server somehow is running jobs under an user account. For me Ansys works but for others not.
      If I run a test job through RSM configuration it fails.
      JobType is: SERVERTEST
      Final command platform: Windows
      RSM_PYTHON_HOME=C:Program FilesANSYS Incv212commonfilesCPython3_7winx64Releasepython
      RSM_HPC_JOBNAME=RSMTest
      Distributed mode requested: True
      RSM_HPC_DISTRIBUTED=TRUE
      Running 5 commands
      Job working directory: C:Usersserver_accountAppDataLocalTempRsmConfigTest	c4xbtww.1dq
      Number of CPU requested: 1
      AWP_ROOT212=C:Program FilesANSYS Incv212
      Testing writability of working directory...
      If you can read this, file was written successfully to working directory
      Writability test complete
      Checking queue FullSpeed exists ...
      JobId was parsed as: 44
      Job submission was successful.
      Job was not run on the cluster. Check the cluster logs and check if the cluster is configured properly.
      Arcnode log
      2022-03-16 16:39:58 [INFO] RunWindowsProcess Is System Account
      2022-03-16 16:39:58 [INFO] Running job 44 as DASTUDuser_account from NT AUTHORITYSYSTEM
      The arcnode process should run it as server_account and not user_account I think. Seems a bit strange. How can I change this?
      (account names changed for privacy and security)
      Edit:
      It seems to be the userproxy process. But what does this do? Other users other than 'user_account' should be able to use RSM as well.
      2022-03-11 10:47:35 [INFO] No UserProxy processes having arguments " -primary DASTUD_user_account" found for account DASTUDuser_account
      2022-03-11 10:47:35 [INFO] Logging on DASTUDuser_account...
      2022-03-11 10:47:35 [INFO] Performing post-logon tasks...
      2022-03-11 10:47:35 [INFO] Caching password with Ansys Rsm Cluster (ARC)...
      2022-03-11 10:47:40 [INFO] password:
      2022-03-11 10:47:40 [INFO] Password cached with ARC.
      2022-03-11 10:47:40 [INFO] Launching UserProxy as: DASTUDuser_account
    • Mangesh Bhide
      Right click in RSM job log to show Debug messages too. then please paste entire RSM job log including debug messages
