May 1, 2023 at 12:32 am
mkhademi
SubscriberHi!
I would like to simulate a Rocky project in Batch mode on a Windows system. I have added the path to system environmnet and can open Rocky from command prompt. However, when I am trying to run a project with the syntax below, nothing happens. I am using the same syntax brough in the user manual (Appendice 7.5.1) which is
Rocky.exe –simulate “C:Documentsproject_filename.rocky” –resume=1 –ncpus=7
Thanks for an suggestions.
May 3, 2023 at 1:19 pm
Federico Alzamora Previtali
SubscriberHello,
do you get an error message from the prompt or nothing happens at all?
I believe your path is missing "/" after C: -> "C:/[...]"
May 3, 2023 at 3:41 pm
mkhademi
SubscriberHi Federico,
Thanks for your reply. I get no error message. It is just the program does not run, or it does not create .lock file in the project folder.The path I brougtht above was from the manual. I am using the / in my syntax, like
"C:\Program Files\ANSYS Inc\v231\Rocky\bin\Rocky.exe" -simulate "E:ROCKY DEM\Workshops or tutorials\Static Angle_BatchRocky23\StaticAngleBatch.rocky" -resume=1 -ncpus=20
May 3, 2023 at 5:25 pm
SubscriberBe sure to include two hyphens in your flags "--simulate". Rocky should run in the background.
Let me know if that works.
May 3, 2023 at 6:01 pm
mkhademi
I tried once with the two hyphens, but did not work again. I did the simulations through GUI once. That is why I am using --resume=1. I will setup the simulation again on the GUI without doing the smulations to try again on the Batch mode with the simplest conditions. Meanwhile, can you please write the steps needed to arrange the simulation on Windows with a Batch mode. Maybe I have missed something. For example, Rocky.exe is the only file that must be added to the path? Thank you.
May 3, 2023 at 9:47 pm
mkhademi
I could run the simulations on my laptop with the same syntax you suggested. I should now check to see what the issue might be on my workstation.
Thank you so much.
May 4, 2023 at 12:37 am
mkhademi
Thank you again for proposing the solution. The problem on the workstation was that I had two versions of Rocky 2023R1 and 2022R2. The created project was knows as 2022R2 although created by 2023R1, so the Batch syntax was trying to solve a R2022R2 project using 2023R1 version.
Thank you again for your help.
May 4, 2023 at 12:43 pm
SubscriberI'm glad that you were able to resolve the issue. Thanks for sharing your solution!
May 24, 2023 at 10:02 pm
mkhademi
When I am using the same syntax on the HPC cluster, there will be an error, and inside the error is written "Installing backtrace handlers...success" and the program is not executed. Can you give some general guidelines for running Rocky on the cluster? I have used this syntax:
# Apply resources via SLURM#SBATCH --nodes=1#SBATCH --ntasks=48#SBATCH --time=48:00:00#SBATCH --job-name=rocky_test1#SBATCH -o rockycase239_%j.out#SBATCH -e rockycase239_%j.errmodule purgemodule load rocky/2023R1.1Rocky --simulate “StaticAngle2rocky.rocky” --resume=0 --ncpus=48Thank you. -
May 25, 2023 at 11:53 am
Ansys EmployeeI assume the cluster uses a supported O/S?
May 25, 2023 at 3:40 pm
mkhademi
SubscriberHi Rob,
The cluster is using Red Hat Enterprise Linux (RHEL) version 8.6.
I noticed that I should have given the full path of the rocky file to be run. But, again it gave this error:
Traceback (most recent call last):
File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.1.1-ansys-newlinux/etk/coilib50/source/python/coilib50/__init__.py", line 42, in LoadCppModule
File "/home/jenkins/Work/Jenkins/workspace/rocky30-rb-ROCKY-v23.1.1-ansys-newlinux/rocky30/source/python/rocky30/_cx_freeze_vtk9_hack.py", line 17, in import_hook_wrapper
ImportError: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /software/ansys/Rocky/2023R1.1/rocky/bin/lib/python3.6/_coilib50.so) -
May 25, 2023 at 4:29 pm
Ansys EmployeeSo, no? https://www.ansys.com/content/dam/it-solutions/platform-support/ansys-2023-r1-platform-support-by-application.pdf
May 25, 2023 at 4:47 pm
mkhademi
SubscriberOh I see. This is actually surprising for me, because Fluent is running on RHEL. My default was that Rocky is compatible with any Linux OS where Ansys can be used.
Thank you Rob!
May 26, 2023 at 8:30 am
Ansys EmployeeAnsys acquired Rocky & team from ESSS earlier this year, but we've been working with them for longer. As it's from a different development background the OS list is slightly different. It's also gpu focussed with a cpu option so OS requirements are a little different.
Fluent came from UNIX, and then moved onto LINUX and Windows.
There may be a library you can port, otherwise keep an eye on the release notes as I'd be very surprised if more OS support wasn't in the plan. Note, I don't know about the plan!
5454
3419
2473
1310
1022
