April 13, 2023 at 4:39 am
song0017
SubscriberHi,
I have configured and am using the ANSYS RSM (ARC) system.
However, there is a problem with storing the credentials of the nodes on the master computer.
Saving the password using 'arccredentials -a node1\administrator' on the master computer works normally for a certain period of time (several hours).
However, after a certain amount of time, errors related to the credentials between the master and the node occur.
The following is a log when an error occurs.
472 2023-04-13 AM 10:24:04 Info Error: System.Security.SecurityException: Error trying to login as master\Administrator on node1: Username or password is incorrect
473 2023-04-13 AM 10:24:04 Location: Ansys.Rsm.Utilities.Logon.WindowsLogon.LogonUser(String user, String domain, SecureStringWrapper password, LogonType type, LogonProvider provider, Boolean doRetry)
474 2023-04-13 AM 10:24:04 Location: Ansys.Rsm.Utilities.Logon.WindowsLogon.LogonUser(String currentUser, String user, String domain, PasswordEntry credentials, LogonType type, LogonProvider provider, Boolean doRetry, IDictionary`2 environment)
475 2023-04-13 AM 10:24:04 Location: Ansys.Rsm.Arc.Core.Logon.LogonUtilities.LoginUser(PasswordEntry credentials, GenericLogon logon, String workingDirectory, IDictionary`2 environment)
476 2023-04-13 AM 10:24:04 Location: Ansys.Rsm.Arc.Node.NodeHandler.TryLoginAndStartWindowsProcess(ILaunchProcess processData, PasswordEntry credentials, Tuple`2 applicationAndArguments, Boolean quoteArguments, JobKillHandle stopHandle, CommandLineCommand& command, IExternalOperationResults& externalOperationResults)Also, when an error occurs, storing the credentials of one node using the 'arccredentials' command will make the other nodes work properly as well.
How can i solve this problem?
Thank you.
May 15, 2023 at 12:28 pm
Mangesh Bhide
Ansys Employeeverify that Active Directory in use or central authentication so same credentials can access all resources.
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5364
3363
2471
1310
1018
