October 14, 2018 at 2:14 pm
rounaksingh
SubscriberHi,
Anybody have any knowledge about python scripting in Savant? I am trying to generate complex geometry with different dielectrics. I want to find transmission coefficients between two antennas in a complex environment. I have tried with HFSS but the enviroment is large for it.
Any help is appreciated!
October 17, 2018 at 9:09 pm
3Asif
SubscriberHello,
The newer SBR+ (shooting bouncing ray) may be helpful.
You may record script inside Ansys Electronic Desktop Environment and re-use it.
-3A
October 17, 2018 at 10:49 pm
rounaksingh
SubscriberHi 3Asif,
Thanks for your reply!
Savant is different from Ansys Electronics Desktop. It has a different GUI. I can't record a macro/script in Savant.
- Maxwell, HFSS or Q3D?
- Error
2678
2120
1349
1136
461
