April 28, 2022 at 10:36 am
aldamo
SubscriberHi All,
So i have to add a 4000N force over the selected surface. I'm currently able to identify the surface and select the magnitude, but I have problems with the force direction. The code I wrote is the following:
April 28, 2022 at 10:50 amErik Kostson
Ansys EmployeeHi
To use these directions just use the record option inside the scripting console, and see how it works.
For instance to define it in the x direction would be:
threadForce = ExtAPI.DataModel.Project.Model.Analyses[0].AddForce
threadForce_scoping = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
threadForce_scoping.Ids = [4]
threadForce.DefineBy = LoadDefineBy.Components
threadForce.Location = threadForce_scoping
threadForce.XComponent.Output.DiscreteValues=[Quantity(400,"N")]
Erik
May 17, 2022 at 12:01 pmaldamo
SubscriberThanks EriK!
Viewing 2 reply threads- The topic ‘Ansys Scripting – Add Force along Cylindrical surface’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
