Ansys segmentation erro
    • mohit
      I'm running an cfd analysis in ansys fluent and after a couple of iterations, the window just closes it self. Here's the error :
      Node 0: Process 15016: Received signal SIGSEGV.
      job aborted:
      [ranks] message
      [0] terminated
      [1-3] process exited without calling finalize
      ---- error analysis -----
      [1-3] on DESKTOP-M2UHJN0
      C:\PROGRA~1\ANSYSI~1\v202\fluent\fluent20.2.0\win64\3ddp_node\fl_mpi2020.exe ended prematurely and may have crashed. exit code 2
      ===============Message from the Cortex Process================================
      Fatal error in one of the compute processes.
      My system config: i7 11th gen 64gb ram 12gb graphics card.
      Let me tell you this is my new system, and I installed everything just today itself. The things that I have tried and havent worked:
      1. Running the simulation without UDF
      2. re-installing windows
      3. Simple cfd analysis is completed, the problem lies with complex flows.
      Can anyone help me please?
      If the solver is failing after a couple of iterations and it's not the UDF, check the mesh quality. What models are you using?
