Ansys Free Student Software
Topics cover installation and configuration of our free student products
ANSYS SERVER ERROR
    • GIOVANNI PARKINS
      GOOD DAY
      Im experiencing the problems below, when trying to run/analyse within ansys electronics desktop. any advice or suggestions on fixing this is highly appreciated.
    • Faezeh Ladani
      Hi Giovanni,
      The error code  - 1073741819 is a Windows error message, which might not have to do anything with your AEDT project. But if related to your project, try the followings:
      It can be a memory access violation. For some reason, AEDT could not access memory. Sometimes, it is out of memory for a large design, or user permissions.. Sometimes, it may even go down to hardware fail.
      Also, make sure the path of the project (consisting of the name of the design, project, and the nested folders you save the file in) is not very long and close to 256 char limits. From the picture, this doesn't look to be the reason, but keep that in mind.
      Make sure you run on a disk with enough space, and with all read/write permissions for the user,  and also empty up the Temp folder.
      Hope this helps. If the issue remians, you may search the error code on Microsoft forum or other platforms to investigate further. Also, check if it is happening only for this project, or happening in different AEDT/other projects as well.
      • GIOVANNI PARKINS
        Hi Faezeh, thank you for the reponse I really appreciate it and will look into it. I recieved an error earlier when the configuration of ansys em suite suit completed and would like to know if it could possibly be linked. i will attach the screenshot below. Id appreciate your assistance.
        kind regards giovanni
