Ansys Sherlock not importing ODB file
    • narendra18muley
      When i import odb file in sherlock software, it doesn't produce same analysis as given in user guide tutorial.
      Same is the case with other file formats also.  Please see the image attached herewith.display shown after file is imported
    • egyvb1
      Hi there,
      From my understanding Sherlock works best with EDB files. If you are using an ECAD software such as Altium, you should be able to use an add on that will convert the ECAD into Ansys EDB files. I hope this helps.
      • narendra18muley
        Sure, I'll try it out.
        But the thing which worries me is that even Tutorial ODB file provided by sherlock is not opening. The log files box remains empty. And if I change any property in life cycle and save, a pop up comes and says "JAVA NULL pointer exception" ...
        Can u identify what is wrong?
        btw thank you for responding!
