December 14, 2019 at 10:28 am
Losiola
SubscriberHello ,
I am new to ansys and i dont have that much of informations about it so hope that you can help me with this topic .
i am making a 2D airfoil simulation using Ansys Fluent on my own laptop i7 (4 cores -8 threds) i ve run the simulation on fluent specifiying parallel with 6 process .
later my professor provided me with a Z820 workstation with the same version of ansys but with 2 CPU (24 cores-48threads) , i was super excited and i wanted to know how fast it gonna go .. so i run the same simulation on the workstation in paralle specifying 36 processes but i was schocked when i found that the worstation in only 2 faster than my Old laptop !!!!
1/-Do you have any idea about what might be the problem ?
2/-Does this has any relation with HPC license !!
I appreciate any help that you can provide.
Kind regards
December 16, 2019 at 12:09 pm
Ansys EmployeeParallel does scale well, but as you put more cores in you also have to "pay" for data transfer between cores/nodes. Eventually the data transfer out weighs the speed boost for using more cores. For many Fluent models we're good down to 10-50k cells per core but it's also model dependent. Don't use hyperthreading either: it's not designed for CFD models.
December 16, 2019 at 6:06 pm
Losiola
SubscriberOk ,
i guess than that the problem is with the hyper threading ,Do you suggest that i disable it from BIOS ?or just keep it and instead of using logical cores keep the number of processors 24 Cores ?
December 17, 2019 at 12:26 am
SubscriberYes, disabling hyper threading is recommended by ANSYS. You will be limited to 24 cores, but 23 cores might end up being faster.
December 17, 2019 at 8:25 am
Losiola
SubscriberThank you very much for the assistance i ve disabled hyperthreading and used 20/24 cores and the improvment is amazing .
Thank you all
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5364
3363
2471
1310
1018
