March 13, 2023 at 9:07 am
Darin Tsai
SubscriberAftter running DC IR Sim on Siwave 2019 (Can also run on 2022) for current drop/density, is there anyway to get magnetic flux or field plot that would be similar to this. Or is there any way to export all the data in the 2d coordinate plane to like a spreadsheet to manually calculate it. Was also considering using Electornics' Maxwell, but not exactly sure how.
- Maxwell, HFSS or Q3D?
- Error
3646
2512
1735
1226
578
