Ansys Products
Ansys Products
ANSYS SPACE CLAIM not working
    • Hemnathmdm15d002
      Hello sir/madam,
      We are using a licensed version of ANSYS ACADEMIC 19.3 as well ANSYS RESEARCH at our institute.
      I am facing an issue while using ANSYS SPACE CLAIM. It was working normally, but from today it is not working or opening. When i tried to open it, it's prompting with an error " Geometry editor was closed abnormally". Could someone help me to resolve this issue?
      Adding to the above, in this path
      C:Program FilesANSYS Incv195commonfilesconfigswinx64config
      I could not find AnsConfigSpaceClaim.exe
      I would like to get it resolved as soon as possible.
      Attached the registry editor screenshot as well.
      Thanks in advance
      Hemnath
    • tsiriaks
      If you reinstall, do you still miss this AnsConfigSpaceClaim.exe ?
      It should exist, otherwise, you can't configure SpaceClaim.
    • Hemnathmdm15d002
      Yes sir. I have completely uninstalled and reinstalled the package. Still having the same issue.
      Last week i faced an issue like the "ANSYS WORKBENCH" was launching but when i tried to maximize from the taskbar, I was unable to see the window.
      On seeing some online solutions, i used sfc /scannow in command prompt to resolve it. After that workbench started working well.
      Would that have caused a trouble to spaceclaim.exe
    • tsiriaks
      That's because it's off-screen. You can refer to
      https://studentcommunity.ansys.com/thread/workbench-not-opening-2020-r1/
      Even though that's resolved, it's still good to try the 'move' command that I mentioned in that post again as it could help with other issues that you may have too.
      I'm not sure how the AnsConfigSpaceClaim.exe is missing. Can you re-download the installation package from the website ? What's the name of the package (the file name)
      Make sure you completely remove your current ANSYS Inc installation folder before you proceed with the re-installation. Also, use 'run as administrator' when running the setup.exe (the installer)
      Is AnsConfigSpaceClaim.exe still missing ?
    • Hemnathmdm15d002
      Thanks for the first solution regarding the off screen. It got resolved.
      For the issue regarding spaceclaim, I have downloaded STRUCTURES_2019R3_WINX64 package from the website and that too working smooth without any issue. nMuch Thanks Mr. tsiriaks:)nn
    • tsiriaks
      That's great ! Thank you for the update. I'm glad everything is good now n
Viewing 5 reply threads
