Discovery Import
Discovery Import
Ansys SpaceClaim export to 2D DXF
    • jinson
      Hi
      Is there any solution
      when open dxf file export by spaceclaim, the circle become spline line
    • jinson
      the size of circle is 1  mm and below
    • Charudatta Bandgar
      Hello jinson
      Let me look into this and I will get back to you.
      In the mean time can you try exporting again after switching between Teigha and Autodesk RealDWG, and see if it helps?
      Regards.
    • jinson
      Charudatta Bandgar
      exporting option tried
      still same result
      Hello jinson
      Are you opening the SpaceClaim exported file in any CAM software? What happens if the DXF file is again imported back in SpaceClaim, do you see the circles as spline? (This will clear up the possibility of the issue being with the translators on the CAM software).
      Regards.
    • jinson
      hi Charudatta Bandgar
      Yes, exported file to any CAM software
      when open back still a circle.
      i have try changing the rendering quality to high ---then the circle will definitely look smooth
      Have try autocad, seem no problem when exported to any of CAM software
      Hello jinson
      When you open the SC exported dxf file in AUTOCAD, the circles come as circles and no issue is faced. Whereas when imported into CAM software, it is getting imported as a spline. Did I understand correctly? If this is correct, I think this is an issue with the CAM software translation, and I would suggest getting in touch with their support. I will still confirm this with the experts and will let you know.
       After you have increased the rendering quality, did the CAM software import, imported as a circle? Can you change the Display>graphics>wireframe and try again and see if that helps?
      Regards.
    • jinson
      have tried below method, the problem still same
      • after change rendering quality still same as picture above (straight line circle)
      • change to wireframe
      • use 2D and 3D method
      Hello jinson
      Based on the information you have given, I think the issue is with the CAM software translation and not SpaceClaim export. I would suggest you get in touch with the CAM software support and see if it is that issue.
      Regards.
Viewing 8 reply threads
