July 31, 2019 at 2:59 pm
tmryan
SubscriberOur Ansys network license is supposed to support SpaceClaim per our sales rep. Below are the only two SpaceClaim-related feature codes in our network license. I removed our customer number. When a student tries to launch SpaceClaim they received a pop-up error (see attached file)
INCREMENT a_spaceclaim_catv5 ansyslmd 9999.9999 07-apr-2020 275
VENDOR_STRING=customer:00##### SUPERSEDE ISSUER=SIEBEL
ISSUED=26-mar-2019 START=26-mar-2019 AUTH={ ansyslmd=(
LK=D03E721B2353 SIGN2="001A 7347 5DB9 A542 A08C F84C BB27 F300
FC54 5731 3C38 38C9 9420 647A 4B06") ansoftd=( SIGN="0028 7AD6
9C70 CFF6 811A B397 7FBB 2000 50EA C597 2A3D 21EF 9FFE A311
E230" SIGN2="00D0 FD61 E03C E5F5 FE85 9E4C E6D0 0200 ACF2 BC73
A610 E0D7 5EEA E59B FB35") }
INCREMENT a_spaceclaim_dirmod ansyslmd 9999.9999 07-apr-2020 275
VENDOR_STRING=customer:00###### SUPERSEDE ISSUER=SIEBEL
LK=DD3E900591B8 SIGN2="00E0 B383 963F EF22 F3A8 72C3 AEEE 3200
1E08 B647 3946 90C1 36E0 9E33 44B2") ansoftd=( SIGN="004E B390
E765 E372 9335 8BBE 33FC 9500 EE84 FA8E 44A1 0F95 9554 FB42
D7A8" SIGN2="000A CD8D F00E A256 5CB0 E163 92DD A200 0B99 F5EB
ECA2 DDB6 5EB8 791F E26C") } -
July 31, 2019 at 5:18 pm
July 31, 2019 at 7:03 pm
tmryan
SubscriberThe version used by the student reporting the error is Ansys 18.1.
July 31, 2019 at 9:32 pm
tsiriaks
Ansys EmployeeThis will be a bit tricky to get it sorted as I may need to see certain data.
What is the ANSYS License Manager version ?
Do you have any license starts with aa ? If so, please list all of them.
If you look at the ansysli_server.log (default) under C:Program FilesANSYS IncShared FilesLicensing on the license server machine, do you see any 'DENIED' or "OUT" from this user ? If so, please post them (and entries around them) here.
Thank you,
Win
August 1, 2019 at 12:29 am
pgl
Ansys EmployeeIt looks like you may have a commercial license and not an ANSYS Academic license. Can you confirm?
If you have an academic license then we only bundled the Faceted Data Toolkit into the core Teaching & Research licenses at release 19.0. Prior to that the Faceted Data Toolkit needed to be purchased separately. So in your case (release 18.1) you should see a separate license increment in your license file relating to the Faceted Data Toolkit. Those two increments in your first post are not the Faceted Data Toolkit.
August 1, 2019 at 12:34 pm
tmryan
SubscriberThe ansylmd.exe is is v11.13.1.2
The ansysli_server.exe is v1.9.7.0
There are no DENIED entries in the server log file for the user, just OUT log entries which are mostly for "aa_r"
Also, there are several entries in the log file that show "Last 10 Client Requests Processing Time (in ms)" with a bunch of other users.
You can see the user edejesus in these entries. e.g.:
20:40:13 (lmgrd) TIMESTAMP 7/29/2019
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) ===============================================
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) Time: Mon Jul 29 2019 21:07:58 Eastern Daylight Time
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) 00000000 ms at 21:01:58(7/29/2019),#11,(4404K),(edejesus-adm,edejesus-pc,444)
21:07:58 (ansyslmd) (@ansyslmd-SLOG@) 00000000 ms at 21:01:58(7/29/2019),#11,(4404K),(edejesus-adm,edejesus-pc,428)
There are four feature codes that start with aa_ as seen below. All the rest do not sta
INCREMENT aa_mcad ansyslmd 9999.9999 07-apr-2020 275 9A845559953B
VENDOR_STRING=customer:00246994 SUPERSEDE ISSUER=SIEBEL
ISSUED=26-mar-2019 START=26-mar-2019 SIGN2="0078 92E5 CCAE
745B 6060 7011 0A4F AA00 0AB4 E893 903B B710 902F 3644 56C8"
INCREMENT aa_r ansyslmd 9999.9999 07-apr-2020 25 DCFBF9BD7082
ISSUED=26-mar-2019 START=26-mar-2019 SIGN2="009A 06FE 62D6
51AD CB88 71E4 D112 4A00 8837 161A 9AE7 AE14 B1C4 3B06 CFE8"
INCREMENT aa_r_hpc ansyslmd 9999.9999 07-apr-2020 128 7F42BBC3C1F4
ISSUED=26-mar-2019 START=26-mar-2019 SIGN2="00F6 18F6 A5E2
A482 F2A8 DC0E 5804 EB00 5A90 9173 48E2 472D 592F 1E85 00E6"
INCREMENT aa_t_a ansyslmd 9999.9999 07-apr-2020 250 3682C3A6EB33
ISSUED=26-mar-2019 START=26-mar-2019 SIGN2="0058 BB59 38A3
66E1 4BF0 B303 A8CB 5E00 3E1D B370 DFA2 64AB A09D EDFD 785E" -
August 1, 2019 at 12:55 pm
tmryan
Based on the information shared in the link below. Looks like we may need to upgrade our Ansys license manager to 2019 R2.
https://forum.ansys.com/forums/topic/error-capability-faceted-data-toolkit-for-spaceclaim-does-not-exist-in-the-ansys-licensing-pool/
August 2, 2019 at 12:04 am
tsiriaks
Ansys EmployeeYou can try updating the version of License Manager to 2019 R2. If that doesn't work, please post content of a'nsysli_server.log' . Your log above is from 'license.log' , which is a different log.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2616
2098
1323
1108
461
