January 20, 2021 at 10:44 pm
jehanxt
SubscriberQuestion
I’m currently trying to apply a solar ray in the range from 250-1700nm on a surface. Below is a picture that represents the spectrum irradiance of the solar light. (I need this because I’m applying this light on a fluorescent dye material)
January 26, 2021 at 2:55 pmKarthik R
AdministratorHello,nHere is a link that contains all the information you need related to the Environment source / ambiant CIE sun.nPlease also see the following help link related to US Standard Atmosphere 1976.nPlease note that this is available only for Premium Pack.nI hope this helps.nThank you.nKarthiknViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Negative Reflection Problem
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- 超透镜聚焦效率
- HUD simulation Speos
5290
3311
2471
