March 12, 2021 at 7:53 am
shubhiraj
SubscriberI am performing the simulation of simple bracket but it is showing the error ***** ANSYS COMMAND LINE ARGUMENTS *****n BATCH MODE REQUESTED (-b) = NOLISTn INPUT FILE COPY MODE (-c) = COPYn DISTRIBUTED MEMORY PARALLEL REQUESTEDn 2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESSn TOTAL OF 2 CORES REQUESTEDn MPI OPTION = INTELMPIn INPUT FILE NAME = E:\Ansys\New folder\test-1\_ProjectScratch\Scr7660\dummy.datn OUTPUT FILE NAME = E:\Ansys\New folder\test-1\_ProjectScratch\Scr7660\solve.outn MEMORY REQUESTED (MB) = 1024 n START-UP FILE MODE = NOREADn STOP FILE MODE = NOREADn DATABASE SIZE REQUESTED (MB) = 1024 nn RELEASE= Release 19.2 BUILD= 19.2 UP20180808 VERSION=WINDOWS x64 n CURRENT JOBNAME=file0 13:12:27 MAR 12, 2021 CP= 0.125 *** FATAL *** CP = 0.125 TIME= 13:12:27n The memory (-m) size requested [1096 mb] is not currently available. n Reenter ANSYS command line with less memory requested. nn ************************************************************************n The above error is non-recoverable by ANSYS n ANSYS run terminated by the indicated error n Current database saved if possible. n -
March 15, 2021 at 10:51 am
1shan
Ansys Employee,nDoes your PC have a 4GB RAM? If yes try restarting your PC and rerun your simulation (without any other applications running simultaneously). Also, check out https://forum.ansys.com/discussion/4171/an-unknown-error-with-memory-occurred-during-solution. Let me know if it solves the issue.nRegards,nIshan n
Trending discussions
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
