August 1, 2018 at 7:04 pm
Abhijeet Das
SubscriberI downloaded ANSYS STUDENT 18.2 one month ago which had a validity duration of 12 months. I have just used it for a month and its popping up a message that my "license is going to expire in next 29 days ". I checked it again via .lic file and its showing that my expiration date is 31/08/2018. How to renew ??
August 1, 2018 at 8:40 pm
dsurendr
Ansys EmployeeHello Abhijeet,
I would recommend you to download and install ANSYS Student 19.1 (latest version) - the license file that comes with this version would be valid until 30-April-2019
August 1, 2018 at 8:56 pm
dsurendr
Ansys EmployeeAbhijeet,
Please also make sure that you install in the same directory as the v182 (Default would be C:Program FilesANSYS IncANSYS Student)
Thank you.
August 1, 2018 at 10:27 pm
tsiriaks
Ansys EmployeeHi Abhijeet,
Also, to clarify about the 'license duration' . This is not 'usage duration' . It always has a fix expiration date. So when it approaches that date, regardless of how much you've used it, it will expire.
Thank you,
Win
August 2, 2018 at 5:22 am
Abhijeet Das
SubscriberSo please can you suggest me how to renew it after expiration ?
Regards
Abhijeet
August 2, 2018 at 4:43 pm
tsiriaks
You can follow Divya's suggestion to install v19.1 in the same directory that your 18.2 is installed on.
This would update the student.lic file under (default location) C:Program FilesANSYS IncANSYS StudentShared FilesLicensing
So, you would be able to extend the license for v18.2 and can also use it with v19.1
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2564
2068
1289
1106
459
