October 12, 2021 at 9:47 am
LunarSun
SubscriberHi, I keep getting this error when I try to solve in static structural mechanical. I'm running windows 10 and my pc meets the specs that ANSYS requires. Any help would be appreciated thanks.
*** ERROR *** CP = 1.422 TIME= 10:43:20
An unexpected error ( SIG$ILL ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program.
Current ANSYS Traceback:
mf2Factor
DSPmain
SolveFULL
svkan
solvcl
ANSYS
October 12, 2021 at 10:59 amLunarSun
SubscriberSorry it's ANSYS 2021 R2
October 12, 2021 at 11:55 amLunarSun
SubscriberManaged to solve it.
I had to go to solve process settings > advanced > and untick ''distribute solution''
May 21, 2022 at 2:50 pmAndrea_Anastasio
SubscriberHey there! I write here cause I had exactly the same ERROR MESSAGE, which is:
"An unexpected error ( SIG$ILL ) has occurred...ANSYS internal data
has been corrupted.ANSYS is unable to recover and will terminate.
Previously saved files are unaffected.Please send the data leading
allow ANSYS, Inc to improve the program."
I see that you managed to solve the problem by modifying that option, but my problem is that I am not using the "general" Ansys software, but just the MECHANICAL APDL 2022 R1. The problem started when I installed the new version (before this one I used 2020 version, but I never had a single issue): i can open the software and modify all the options in th preprocessor, but when it comes to click "SOLVE", that message appears and when I click "PROCEED", suddenly it crashes and it closes by itself. I post a screenshot to better understand:
I tried downloading another version, such as MECHANICAL APDL 2021 R2 (as yours), but the problem is still the same.
Please, help me!!!!
May 21, 2022 at 3:13 pmAndrea_Anastasio
SubscriberOk guys, that's really an incredible coincidence. I've been looking for a solution to my problem for months, literaly. By the moment I posted the question, I instantly found the answer on another forum!!!!
If someone else has the same problem with MECHANICAL APDL, no matter the version, I suggest to visit this forum:
https://forum.ansys.com/discussion/comment/156713#Comment_156713
The answer is provided by the person with the nickname "nsiwac".
This is definitely a turning point day to me. So happy.
Good work to everyone!!!!!!!!!!!!
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3744
2573
1809
1236
594
