January 30, 2022 at 3:31 am
mzhossain2001
SubscriberI am getting the following error message after running Mechanical APDL. Any fix will be appreciated.?
February 1, 2022 at 2:45 pmGeorge Karnos
Ansys EmployeeHow much RAM do you have on your machine?
Does it run if you use one of the other solvers?
February 1, 2022 at 3:00 pmmzhossain2001
SubscriberI have 8.0 GB of RAM.
I DONT USE MORE THAN ONE SOLVER. THANKS.
February 1, 2022 at 3:05 pmGeorge Karnos
Ansys EmployeeDoes this error happen with all solves or just this specific one?
February 1, 2022 at 3:14 pmmzhossain2001
SubscriberI didn't try with others solvers
If I run mechanical apdl with workbench, it runs with small model. Like 100 elements. But if I go for larger model like 1000 element. I get that error message, as the screen shot is showing.
If I run any model even smaller with mechanical apdl without using workbench - I always get that error message as the screen shot is showing.
Thanks.
February 1, 2022 at 4:29 pmmzhossain2001
SubscriberTo add further - I have 550 GB free space on my hard drive. I am running other softwareissue. RISA. STAAD. with large models without any issue.
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5242
3281
2467
