Ansys Free Student Software
ANSYS STUDENT 2022 R2 WINDOWS 11 UNKNOW ERROR
    • turca petrica
      Good day gents,
      I have a problem after installation of ANSYS STUDENT 2022 R2 on my WINDOWS 11.
      Issue looks like that in the picture : Is an error without any message and when i look in the license folder,i believe some files missing.
      Please give me a solution to fix it cause i need it for Master degree courses.
      Best regards,
    • George Karnos
      When you installed, did you right-click on setup.exe and choose "more->run as administrator" ?
      under C:\Program Files\ANSYS Inc\ANSYS Student There should be an install.log file and maybe a an install.err file. Do those shpow any errors?
      If you did not right-click run as administrator, try uninstalling and reinstalling.
      Also, check visrus scanning and firewalls for any blocking going on.
    • turca petrica
      Hi George,
      Thanks for the answer ! I stop firewall and antivirus plus also give permission to install as Administrator, still have the same problem.
      Also i check the installation Log and all i can see wrong in there is this : Discovery workbench plugin in ... Not Configured .
      Any other suggestion will be welcome !
      Best regards,
