Ansys Products
Ansys Products
ANSYS STUDENT R3 INSTALLATION PROBLEM/ ALL SETUP MENU FROZEN
    • Marta13
      I have tried to install 2019 R3 ANSYS STUDENT. No problem with download but when executing Setup.exe with administrator role, all setup menu shows frozen and i cannot progress.
      I have checked the following post
      https://studentcommunity.ansys.com/thread/problem-with-installation-of-ansys-19-2/
      and applied recommendation on language pack. I have changed from spanish to english and repeated download, unzip and setup execution and same results.
      Can you please help?
    • zafer1
      I have same problem with 2020 R1. Need help
    • Tiwock
      I've just downloaded and installed the 2020 R1 package, but I had some identical issues as described in the link you provided.
      My download folder is not on my main partition (because it's a ssd, and I don't want to constantly write on my SSD, which would both take a lot of useless space and damage the disk). So I moved the extracted folder to C:Documents and then ran the setup. It solved the problem.
      Hope this could work for both of you
    • zafer1
      Oh ok! i don't have a SSD but i will move all setup files to an external HDD or flashdisk and try to setup from there. I think it will make the same work. Thx for your support hope it solve this issue.
    • Marta13
      Hey, thank you very much! Moving the folder to the C: disk and then doing the setup actually solved the problem. Thanks for the tip again, already using it!
    • zafer1
      it solved my problem too. Thank you so much!
    • tsiriaks
      Thanks for sharing your resolution Tiwock
Viewing 6 reply threads
