ANSYS thinks Temp is below material property range
    • helen.durand
      Hello!
      I have specified temperature units of K in every place that I know about within a transient thermal Workbench simulation, but I am receiving messages such as the following in the solution output.
    • Ashish Khemka
      nnThe message above is just highlighting that the temperature specified initially is outside the given temperature range for properties. It should not be a concern because the analysis will proceed as per the defined properties. Below temperature of 298.15K the density will be 4770kg/m^3.nnRegards,nAshish Khemkan
