Ansys Products
Ansys Products
ansys tutorial 2.1 for 19.2 a few deviations from the tutorial/stuck points
    • TravelingModel
      I'm finding a few differences from the manual (downloaded PDF or the online version) to following the steps. I have gotten around 2 of the hurdles, one a GUI issue and the other some steps missing from the tutorial paperwork. But this one, on the step 2.1.7.1 solving. I cannot find the Main Menu> Solution> Solve> Current LS
      I can see under the solution tab, a few other options. i tried it in APDL classis, and APDL mechanical product launcher. But nothing with the above hierarchy of commands. I did fiddle around under Analysis type, but still stuck. any ideas?
      thanks,
      Will
    • Saumadeep
      I guess you are referring to this link - 2.1. Static Analysis of a Corner Bracket (ansys.com)
      In Mechanical APDL you will be able to get this option - Main Menu> Solution> Solve> Current LS
      Regards, Saumadeep
    • TravelingModel
      hello! that's not available in my version at work. i forced it in, using the command line solve
