August 19, 2019 at 5:46 am
bobby
SubscriberHello guys,
Does anyone know about the tutorial how to design tubular (cylinder) single lap joint in Ansys?
I have searched the related tutorial on youtube but it still can't answer my problem.
If you know or you can, please contact me by email : hakabobby@gmail.com
I really need your help. Thank you
I attach picture here to give you an illustration.
August 19, 2019 at 2:51 pm
SubscriberHello bobby,
What loads do you have to apply to that structure?
1) Draw the geometry in a CAD system. If you have no CAD system, then start with SpaceClaim. Create a component for the larger pipe, and create that solid body, create a component for the smaller pipe and create that solid body. Then create a component for the joint filler, and create that solid body.
2) Bring that Geometry into a Static Structural analysis. Mesh it, apply loads and supports. Create contacts between the bodies. Solve. Review results.
Note: ANSYS staff are not permitted to open attachments, so please Insert Image directly into the post.
August 19, 2019 at 3:10 pm
bobby
SubscriberHello Peteroznewman,
Thank you for replying my question.
I would like to apply dynamics load to that structure so I will do modal analysis.
I've tried to draw geometry in Ansys, but it's hard for me how to make 3 parts then connect them together?
*by the way the picture that you sent to me was same with my 2D sketch problem
August 19, 2019 at 8:22 pm
SubscriberYou have to spend some time learning the SpaceClaim CAD system. There are tutorials here.
Send the values for R, c, L, t1, t2 and t3 so I can show you.
August 20, 2019 at 3:22 am
bobby
SubscriberYes sir thank you for your advice. Currently, I spend my time to learn about the SpaceClaim CAD system.
here the values for that design :
R= 12.5 mm
c= 20 mm
L= 250 mm
t1= 1.0 mm
t2= 1.0 mm
t3= 0.2 mm
thank you in advance for your help.
2120
1347
1118
461
