December 12, 2020 at 1:20 am
roshanpjos
SubscriberHello, I am using ansys UPF for creating a user element. I use /upf,UserElem.F in APDL script for calling my Fortran UserElem.F subroutne. However, I get the following error. Warning:missing /upf file (routine) - UserElem.Far:*.o:No such file or directorynI put the UserElem.F in the working directory. Is there anywhere else I need to put it? Is there any problem with setting my working directory? Is there any scripts I need to use for setting my working directory in apdl script? What could be the problem? -
December 14, 2020 at 1:10 pm
Ashish Khemka
Forum ModeratornnPlease refer to the following guideline on UPF, as per Ansys Help and see if you are following the process as indicated:nRegards,nAshish Khemkan -
December 21, 2020 at 7:02 pm
roshanpjos
SubscriberThank you very much Ashish.n
- A solver pivot warning or error has been detected
8786
4658
3151
1678
1468
