November 23, 2020 at 1:07 pm
havinarslan
SubscriberHello,
After the installation of ANSYS Student V202 the error file exists (images are given below). Could you help me?
November 23, 2020 at 1:11 pmANSYS_MMadore
Ansys EmployeeCan you share the contents of the install.err file? Are you having problems running ANSYS after the installation?.Thanks,nMattnNovember 23, 2020 at 1:21 pmNovember 24, 2020 at 6:00 amNovember 24, 2020 at 12:54 pmANSYS_MMadore
Ansys EmployeePlease try to uninstall the current copy, you should find an Uninstall.exe at C:\Program Files\ANSYS Inc\ANSYS Student\v201. Next, please download a new copy of the ANSYS Student installer and make sure you extract the downloaded installation media before installing. I recommend saving and extracting in your Downloads or Desktop. Then be sure to right-click on the extracted setup.exe and select Run as administrator.nnThank you,nMattnViewing 4 reply threads- The topic ‘Ansys V202 student version after installation problem’ is closed to new replies.
Trending discussions- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1680
1470
