November 10, 2020 at 4:30 am
mhmdsh
SubscriberHi,
after I download the student version
i followed the instructions for installing the program
but after installation, ansys workbench does not appear on the main menu
so i searched for a solution here and i founda solution that we can find or run the workbench there:
November 13, 2020 at 12:47 pmGeorge Karnos
Ansys EmployeeHello, nWhen you installed the program, did you right-click on setup.exe and choose: more->run as administratornIt sounds like a permissions problem when installing, if the menu items were not added.nnNovember 14, 2020 at 4:03 ammhmdsh
Subscriberyes I didnnViewing 2 reply threads- The topic ‘Ansys W.B doesn’t open’ is closed to new replies.
Trending discussions- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1680
1470
