We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
Topics related to Mechanical Enterprise, Motion, Additive Print and more.
Ansys Warning : Contact status has experienced an abrupt change .
    • malbaro
      Warning : contact status has experienced an abrupt change .nAfter this warning the problem does not converge at all. I have looked up this issue, and was recommended to use sub steps to gradually apply the loads. nContact type : FrictionlessnThe thing is the problem converges if the applied force does not cause the contacts to separate, but it will throw this warning and does not converge if the applied force is significant to cause the separation. nAny solutions ? How do I use sub steps ? or is there any other Analysis or contact settings I need to be aware of ?n
    • Aniket
      Forum Moderator
      For substeps, please check:
      simple check would be are there other things that keep the model together if the frictional contact is open? Do a Modal analysis first with the frictional contact suppressed and see if the model is adequately constrained in the contact open case.
      -Aniket
    • Ladderdale
      That could indicate that your model is unconstrained or that one of your contacts are open
      Insert contact tool and check if any of the are open. You can right click on any contact and a click on " go to selected item in tree"
    • joecui
      Hi! Do you solved this issue right now? I'm facing the same problem now. Could you share the experiment how you solved this problem ?
      -Joe
Viewing 3 reply threads
  • The topic ‘Ansys Warning : Contact status has experienced an abrupt change .’ is closed to new replies.
