Ansys Free Student Software
Ansys won’t open on my computer.
    • andie
      To whom it may concern,I had to download Ansys Student 2020 R2 for one of my classes at the University of Alberta, but for some reason workbench, along with all other aspects of the program, quit automatically before I see the screen. I have tried uninstalling and reinstalling the program several times, and the same issue keeps happening. I have found the following error within the installation and uninstallation notes – I hope it helps.nn nnErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v202\CADConfigLogs\CADConfigurationMgr.errnn
    • DrAmine
      Make a clean uninstall and install with explicit Admin Rights (Run as Admin ) is not enough to install as Admin.n
    • andie
      I don't understand? I tried to install as Admin, but how would I run it as Admin as well? Should workbench not just work after the installation process? n
    • tsiriaks
      That note is not for an error. It tells the location of the error file but it's for CAD Configurations, which is not the issue you are having here.nYou mean you are trying to launch Workbench but it doesn't do anything ? Did you see splash screen ? nIf it crashes that early, it normally has something to do with security software blocking it.nYou can also check Windows Event Viewer -> Custom Views -> Administrative Events and see if there is any event logged when you tried to launch Workbench and it crashed. If so, post the details of that event here.n
    • andie
      I opened Workbench once successfully, but now it keeps quitting. Here is the XML view of the details.- http:/schemas.microsoft.com/win/2004/08/events/event>n- Application Error />n  0>10000210000x800000000000002020-10-16T20:18:30.0284012Z />n  644660 ThreadID=0 />n  ApplicationDESKTOP-DENNE6Kn- AnsysFWW.exe20.2.0.05ecd4a3aKERNELBASE.dll10.0.19041.5721183946ce04343520000000000023e493c8c01d6a3f97b7127ceC:\Program Files\ANSYS Inc\ANSYS Student\v202\Framework\bin\Win64\AnsysFWW.exeC:\WINDOWS\System32\KERNELBASE.dlle6a2ed56-6621-49a3-85ad-a4a5a5fd71f1nnThe text in the general portion of the administrative events for the error is below.Faulting application name: AnsysFWW.exe, version: 20.2.0.0, time stamp: 0x5ecd4a3anFaulting module name: KERNELBASE.dll, version: 10.0.19041.572, time stamp: 0x1183946cnException code: 0xe0434352nFault offset: 0x0000000000023e49nFaulting process id: 0x3c8cnFaulting application start time: 0x01d6a3f97b7127cenFaulting application path: C:\Program Files\ANSYS Inc\ANSYS Student\v202\Framework\bin\Win64\AnsysFWW.exenFaulting module path: C:\WINDOWS\System32\KERNELBASE.dllnReport Id: e6a2ed56-6621-49a3-85ad-a4a5a5fd71f1nFaulting package full name: nFaulting package-relative application ID: nnAdditionally, an error from the source .NET runtime was encountered, and the details are below.- http:/schemas.microsoft.com/win/2004/08/events/event>n- .NET Runtime />n  0>102602000x800000000000002020-10-16T20:18:29.8120431Z />n  644650 ThreadID=0 />n  ApplicationDESKTOP-DENNE6Kn- Application: AnsysFWW.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException at Tao.Platform.Windows.Gdi.ChoosePixelFormat(IntPtr, PIXELFORMATDESCRIPTOR ByRef) at Ansys.UI.Toolkit.SWF.SWFGLControl..ctor(Ansys.UI.Toolkit.GLFormat) at Ansys.UI.Toolkit.SWF.UIFactory.newGLControl(Ansys.UI.Toolkit.GLFormat) at Ansys.UI.Toolkit.UIFactory.newGLControl(Ansys.UI.Toolkit.GLFormat) at Ansys.UI.Toolkit.GLControl..ctor(Ansys.UI.Toolkit.GLFormat) at Ansys.UI.Graphics.Window.GLWindow..ctor(Ansys.UI.Graphics.IConfiguration) at Ansys.Graphics.Views.ChartView..ctor(System.String) Exception Info: System.Reflection.TargetInvocationException at System.RuntimeMethodHandle.InvokeMethod(System.Object, System.Object[], System.Signature, Boolean) at System.Reflection.RuntimeConstructorInfo.Invoke(System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo) at Ansys.Utilities.FactoryObj 1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].CreateInstance(System.String, System.Object[]) at Ansys.UI.Workspaces.Workspace.CreateView(Ansys.UI.Views.ViewMetaData, Single) at Ansys.UI.Workspaces.Workspace.Create(Ansys.UI.Views.ViewCategory, Single, System.String[]) at Ansys.UI.Views.PageManager.CreateChartPane() at Ansys.UI.Views.PageManager.CreateAllPanes() at Ansys.UI.Workspaces.ASimWorkspace.InitializeLayout() at Ansys.UI.Workspaces.Workspace.Create() at Ansys.UI.MainWindow.Create(System.String, Int32, Int32, Int32, Int32, Ansys.UI.Toolkit.WindowState, Int32) at Ansys.UI.UIManager.CreateWindow(System.String) at Ansys.UI.UIManager.StartUIItems(System.String) at Ansys.UI.UIManager.Start(System.String) at Ans.Program.Runtime.DoRun() at Ans.Program.Windowed.WinExecutable.Run(Ans.Program.CommandLineParse) at Ans.Program.Windowed.WinExecutable.Main(System.String[])n
    • andie
      I just received an unexpected error message that reads:The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will now exit.n
      Search for that error on here as it's been answered elsewhere. n
    • andie
      Hi Rob,While I respect that this has been answered elsewhere on this site, that was the first solution I turned to. I have now wasted over 12 hours of my time trying to figure this out on my own, and would really just appreciate some help delegated to my specific issue as I have a big assignment due this week that I have been unable to begin due to these technical difficulties.
    • MohammadKatibeh
      Hi,nI'm having the same problem. Did you find a solution? I can't find any other thread about it.n
    • DrAmine
      If you do not receive an answer please create a new thread.n
Viewing 9 reply threads
