October 29, 2018 at 6:34 pm
Will_1
SubscriberHi, I'm currently having an issue with my Ansys workbench 18.2 student product. I've look on this forum and tried a few things but none of them worked out for me.
1st: Uninstall ansys and delete folders in %AppData%
After trying this and then run setup.exe, the same problem occured: I don't have acces to any simulation on workbench
2nd: Change date and time in the folders
I've deleted a few folders and changed some date/time in the license server but it didn't work.
What should I do? I need Ansys 18.2 since it's what we use at École de Technologie Supérieure and it's the same product that we use in my scientific club : Chinook ETS
October 29, 2018 at 7:43 pm
pgl
Ansys EmployeeMy best guess is that the built-in license key has expired, as Release 18.2 is now >1 year old.
Can you instead upgrade to the Release 19.2 (or 19.1) ANSYS Student product?
October 29, 2018 at 8:15 pm
Will_1
SubscriberI can't since Ansys sponsored our scientific club ANSYS 18.2 (complete license) and my University is also running Workbench 18.2... I'm afraid that, if I work with ANSYS 19.2 I won't be able to open my work on the school computers...
October 29, 2018 at 11:10 pm
tsiriaks
Ansys EmployeeHi will4074,
So, it worked before on this machine with this username ?
Could you post the screenshot of the output of the 'set' command (without quote ' ') from the CMD Prompt ?
Also, in the Windows search (from taskbar), type
%temp%.ansys
then look for the file that says 'demo.
.log'
Open this file up and scroll to the bottom of the file and post the screenshots of it
Thank you,
Win
October 30, 2018 at 1:37 pm
October 30, 2018 at 4:12 pm
tsiriaks
Unfortunately, like Paul has mentioned, it seems the issue is that your license has expired. However, you can easily renew it without updating the version or even reinstall v18.2 by following my trick posted in this thread
https://forum.ansys.com/forums/topic/license-refresh-without-changing-the-version-of-ansys/?order=all#comment-a42e3ba1-6b6c-450a-ac59-a96f0107b975
Note that you can download any version. We essentially only need the 'student.lic' file from the package.
Thank you,
Win
November 5, 2018 at 3:23 am
Will_1
SubscriberSorry for the late response Win,
Thank you very much for your help! I can finally use workbench.
Will
November 5, 2018 at 6:20 pm
tsiriaks
Ansys EmployeeHi Will,
That's great ! Thank you for the confirmation.
Could you mark the post as 'Is Solution' so that we know this thread is resolved ?
Thank you,
Win
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1349
1130
461
