Tagged: co-simulation, electromagnetic, thermal, workbench
August 12, 2019 at 10:53 am
pushkarkawale
SubscriberHello,
I have a problem in ANSYS Workbench Solution. I have made an analysis setting as Store Output Results at last point only to solve the issue related with disk space. Now in solution, it shows following error message.
Text: "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes."
*** ERROR *** CP = 29929.479 TIME= 21:42
0
The program is unable to open file file.DSP. If the suggestions in the
associated error messages immediately preceding and/or following this
error message do not help resolve the file issue, please send the data
leading to this operation to your technical support provider, along
with the I/O error code of 30 and the system error code of 32, for
help in determining the possible reasons as to why this file could not
be opened.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 1
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
Help me please for this problem.
August 12, 2019 at 11:51 am
Ansys EmployeeWorkbench is a control/workflow tool, which solver(s) were you using?
August 13, 2019 at 6:44 am
pushkarkawale
SubscriberHello Sir, I am using ANSYS 18.0 for my problem.
August 13, 2019 at 9:23 am
Ansys EmployeeThe solver? Ie Mechanical, Fluent, CFX etc. ANSYS 18 is the version, and is now about 2 years old: we're using 2019R2 now.
August 13, 2019 at 11:24 am
pushkarkawale
SubscriberI am using ANSYS Mechanical for transient analysis.
August 16, 2019 at 12:22 pm
DrAmine
Ansys EmployeeCan you try with newer version and get back to us if the issue is still occurring. You require then to add some more information about the issue.
August 23, 2019 at 4:25 am
pushkarkawale
SubscriberThank you all for your kind reply...
2080
1299
1106
459
