ansys workbench design modeler
    • btingthewind
      Dear sir,nRecently I am solving a complex geometry with ANSYS WORKBENCH Design modeler, when the geomerty was loaded, and I use my computer mouse to make it rotate, however, it rotated very very slowly, so what's wrong with it ,and how can I have this problem solved?nBEST REGARDSn
    • subhamdas
      I suspect this to be more of a hardware issue. Check your Memory usage in Task Manager. Also check if you are able to hover the mouse swiftly in case of a simpler geometry(eg. rectangular surface).n
      Also check the graphics card, poor performance can be as states, but for Student models (they're limited to 300 surfaces) it's more often the graphics card. n
