June 21, 2020 at 8:07 pm
uleeh
SubscriberHello,
I am currently playing around with the magnetostatic analysis(workbench), especially the magnetic force of two permanent magnets and was wondering if there was any way to simulate the magnetic field lines and flux generated by the magnets,given the magnetic force and the distance between those two. Thus far I've only found a solution to simulate the magnetic force, given the magnetic flux.
Any help is much appreciated. -
June 30, 2020 at 5:24 am
Navya C
Ansys EmployeeHi,
You can directly implement your problem in Maxwell 2D or 3D to see the Magnetic flux lines, magnetic field densities and find the force exerted on the object at a distance.
Refer to the following Magnetostatic example in maxwell.
File > Open Examples > Maxweell 2D > Solenoid.
Navya
July 1, 2020 at 3:52 pm
uleeh
SubscriberThank you very much.
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1861
1272
610
