March 22, 2021 at 12:01 pm
March 23, 2021 at 12:07 pm
ANSYS_MMadore
Ansys EmployeeArray Was this previously working? Please try renaming your %APPDATA%\Ansys directory to %APPDATA%\Ansys.old.n -
March 23, 2021 at 3:34 pm
dids
SubscriberArraynNo it never worked. Where is %APPDATA%\Ansys, i don't find itnnArrayn -
March 23, 2021 at 5:55 pm
ANSYS_MMadore
Ansys EmployeePlease share the full text of your C:\Program Files\Ansys Inc\install.log and install.err files.n -
March 23, 2021 at 8:36 pm
dids
SubscriberArray n>>>--------------------------------------->nStart Installation: Paz Mar 21 20:49:08 2021nRevision: 2021 R1nnPlatform specifics:n WindowsnUsername of Installer: Apple-PC\ApplenUser Has Administrator PrivilegesnC:\Users\Apple\AppData\Local\Temp\ans_install_tmp2404\instcore.exe -usetempdir C:\Users\Apple\AppData\Local\Temp\ans_install_tmp2404 -launchdir C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510 -adminnInitial mount directory:n C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510nInstallation Directory:n C:\Users\Apple\Desktop\ANSYS Inc\ANSYS StudentnnWindows x64n EnSightDate verification complete...No conflicts found.nnThe installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.nThis may take a while ...nSuccessfully copied prerequisites from media.nnYou don't need to install any prerequisites.nnReading the installation media contents - please wait.nn Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\framewrk\WINX64.7z ...n Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\instcore\tcl\COMMON.TGZ ...n Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\instcore\tcl\WINX64.TGZ ...n -
March 24, 2021 at 11:42 am
ANSYS_MMadore
Ansys EmployeeThis looks like your install didn't go properly. Please download the product again and extract the .zip file. Once extracted you need to right-click on setup.exe within the extracted files and Run as administrator. You should see something similar to this in the install log:nnInitial mount directory:n C:\Users\Apple\Downloads\ANSYSACADEMICSTUDENT_2021R1_WINX64nInstallation Directory:n C:\Program Files\ANSYS Inc\ANSYS Studentn -
March 24, 2021 at 12:18 pm
dids
SubscriberI have both but i don't understand why it makes mistakesn -
March 24, 2021 at 12:23 pm
ANSYS_MMadore
Ansys EmployeeArray Your file indicates nInitial mount directory:n C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510nnThis would indicate that you are not installing from the extracted files, but instead directly from the zip or temp files. You must extract the zip and run the setup from the extracted files. The install.log and install.err should be in C:\Program Files\Ansys Inc\Ansys Student -
March 24, 2021 at 2:47 pm
dids
SubscriberArray I installed again but i didn't see C:\Program Files\Ansys Inc\Ansys Student\ this filenn
March 24, 2021 at 3:05 pm
ANSYS_MMadore
Ansys EmployeeIt may not be C:\Program Files, but wherever you installed it there would be an Ansys Inc\Ansys Student.n -
March 24, 2021 at 3:31 pm
March 24, 2021 at 3:43 pm
dids
SubscriberMy problem is fluid flow (fluent) mesh part. I finished geometry part then i want to edit mesh part but it give error n -
March 25, 2021 at 5:47 pm
ANSYS_MMadore
Ansys EmployeeDid you find the %APPDATA% directory to delete the Ansys files? It is typically C:\Users\Username\AppData\Roaming. Please try renaming Ansys to Ansys.old. Please share the error messages if they persist.n
Viewing 14 reply threads
Trending discussions
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
Top Contributors
2614
2088
1321
1108
459
Top Rated Tags
