ANSYS Workbench Mechanical Legend Display
    • Muhammed
      Hi everyone.
      I am trying to increase the font size of the legend in the Ansys Workbench Mechanical. What is the solution for this?
      Any help is appreciated.
      Thanks in advance.
    • peteroznewman
      Do you only need the font larger when doing a screen grab to paste the plot with legend into a report or presentation?
      If so, you can use the Image to File button.
      Then type a Font Magnification Factor. I typed in a 4 instead of a 1.
      You can also check to use a White Background here.
    • Sandeep Medikonda
      Hi Muhammad,
      You can also write a simple macro such as:
      DS.Graphics.SetFontStyle( 0, 'Arial', 0, 0, 30, 0, 0 );
      DS.Graphics.SetFontStyle( 2, 'Arial', 0, 0, 30, 0, 0 );
      DS.Graphics.Redraw(1);
      Note that the default font size is 16 and here we are changing it to 30 using index 2.
      Lastly, You need to save this macro as a file named “SampleFont.js” in a convenient location. Then from within Mechanical: Tools> Run Macro > SampleFont.js.
      Hope this helps.
      Sandeep
    • Muhammed
      Thank you so much guys. You saved my day!
    • Manasseh Victor
      Can i change the font style from normal to Bond/underline/italic?
Viewing 4 reply threads
