Ansys Workbench Project view shows “Solved” but mechanical shows “Solve Required”. How to fix this ?
    • GeoStrike
    • Rahul Kumbhar
      You can click on Solution and then choose 'Read Result file' from toolbar at the top. You can read the existing file.rst. This should update the status of the solution to the 'solved'.nn
    • GeoStrike
      Thanks for the idea Array. nI had in the meanwhile let the whole project run again. nInstead of clicking on the Update Project, i clicked on Solve in Ansys Mechanical. Worked without any problems.But i will try and replicate the issue and try your solution.Thanks a lot. nAllenn
    • GeoStrike
      Thanks again for the idea .nI had this problem again today morning. and tried your method. Worked very well. nBest Regards nAllen n
Viewing 3 reply threads
