September 10, 2019 at 7:22 am
MBNarkissos
SubscriberI cant open my geometry in WORKBENCH . ? used CAD CONFIGURATION MANAGER 19.2. Can they help me ?
September 10, 2019 at 8:56 am
Ansys EmployeeStaff are not permitted to open/download attachments. How many surfaces are there in the CAD? Can you open anything in R19.2?
September 10, 2019 at 10:33 am
September 10, 2019 at 12:49 pm
Ansys EmployeeUnless you need to alter the Solidworks model from Workbench try it with a dumb export. I don't think Student has the licence you need for the reader so you'll struggle anyway.
September 10, 2019 at 8:24 pm
SubscriberThe Student license does not include the direct CAD interfaces.
Open SpaceClaim, then use File Open and set the extension for SolidWorks which SpaceClaim can usually open.
If you have any issue, in SolidWorks, Save As Parasolid. Then in SpaceClaim, set the extension for Parasolid and Open the file.
September 11, 2019 at 5:39 am
MBNarkissos
SubscriberThank u so much Rwoolhou and Peterznewman. I solved the problem. like u said. First Solid then SpaceClim. Thank u
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2610
2088
1319
1108
459
