Ansys Workbench Solution Problem
    • sina_khm
      I am using the student version of ANSYS Mechanical version 18.2.  I am trying to solve a problem for a structure with ABS properties by using Static Structure module. However, the solution gets stuck at "Preparing the mathematical model" and there is no progress for a long time. It seems the solution is routing between "Preparing the mathematical model" and "Solving the mathematical model". This happens even when I am providing fixed support to the structure from  one end and load at the other end. I have attached the image of my structure and the message that is popping up.
      I have no idea what to do about this.If someone can help me figure this out this would be great! I need help!
      Thank you
    • peteroznewman
      nYou can get an idea by reading some posts that had the same problem you have.nhttps://www.google.com/search?q=site%3Aforum.ansys.com+Not+enough+constraints&oq=site%3Aforum.ansys.com+Not+enough+constraints&aqs=chrome..69i57j69i58.1371j0j15&sourceid=chrome&ie=UTF-8n
