Ansys Free Student Software
Ansys Workbench student version does not open
    • Ayzo Wiertsema
      I downloaded the student version of Ansys. When I try to open the workbench it starts up, but after that it gets stuck. In the picture you can see that the Ansys workbench has started, but when I click on it, it does not open anything. Does someone know what the issue is? And how to solve it?
      Doesn't open, or seems to open but you can't see it?
    • Ayzo Wiertsema
      It seems to open, but I can't see it
      Hover the mouse over the toolbar icon, then right click on the panel bit that appears above it.  The window is probably being displayed on a missing second monitor.
    • Ayzo Wiertsema
      Thanks for the tip, I tried that, but then the same happens it starts up and it seems to open, but it does not actually open
      Odd. Have you rebooted? Sorry, it's the usual IT solution to most things!  Did you extract the downloaded zip then install as Admin onto C: ?
Viewing 5 reply threads
