TAGGED: ansys-fluent, ansys-student, fluent, license-error, licensing
November 18, 2020 at 5:45 am
Lalla
SubscriberI have installed the programme 3 times. Each time, Fluent was not running.nI now reinstalled Ansys, and I was trying to renew the licence, but the WINX64.7z file can't be extracted. I also tried to install the 7z file, as mentioned on another discussion, but nothing changed.nn -
November 18, 2020 at 11:11 am
ANSYS_MMadore
Ansys EmployeeWhat application are you using to extract the file? You need to use 7zip and then you can extract the file.nThanks,nMattn -
November 18, 2020 at 12:11 pm
November 18, 2020 at 12:55 pm
ANSYS_MMadore
Ansys EmployeeThe license you are using is expired. You need to download the 2020R2 version to obtain the updated license file. You may still use 2019R3, but the license from 2020R2 is required.nnThanksnMattn
- The topic ‘Ansys2019R3 installation error’ is closed to new replies.
- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1688
1478
